Brief Description: Mounted Linear Actuator For Nose Trim
Installed the cable housing cable guide into the airframe per plans.
Positioned and drilled mounting holes for the linear actuator mounting brackets behind the right seat. Cut the cable housing and installed from the mounting bracket to the fitting in the airframe.
Ran the cable from the cable attachment fitting through the cable housing and to the control stick, but not yet attached to the spring.
Cable housing fitting mounted in airframe.
both linear actuator brackets drilled and mounted with copper clecos.
