Fabricated final aluminum linear actuator mounting brackets.
Cut from 1/2" aluminum plate, then drilled and tapped as required to be mounted and function properly, and allow cable hardware to be mounted in the bracket, and the tops to be secured.
Cutting the linear actuator mounting brackets from aluminum stock on the CNC.
Mounting brackets after drilling, tapping, and mounting cable hardware.
Nose trim electric linear actuator prliminarily positioned behind the right seat.
