CHUCK'S WEB SITE
Date:  10-10-2022
Number of Hours:  4.75
Manual Reference:  SNB-W03
Brief Description:  Finished Left Aileron And Mounted Both Weights
Drilled and mounted lead counter balance weight on counter balance assembly SNB-$03-03L.
Broke two #40 bits drilling the lead weight between the plates. Pre-bored with 11/64 bit, drilling halfway from each side, then finishing the hole with a single pass through with an 3/16 bit size.
Drilled and mounted lead counter balance weight on counter balance assembly SNB-$03-03R.
Completely deburred the left aileron skin and reassembled the left aileron with copper clecos for final riveting.
Riveted and completed the SNB-W03-03L left aileron.
Initial drilling of the lead counter balance weight for the  right aileron.
Mounting the lead counter balance weight in the counter balance assembly.
Checking to ensure the hinge is attached with the correct amount of lug spacing.
