Removed fuel tank. Drilled and mounted fuel line bulkhead fitting. Drilled 3/4" hole (may enlarge to next step drill size) in glare shield for fuel vent fitting.
Reinstalled tank to verify vent fitting fit through the hole with adequate clearance. Removed the tank and flushed it with water multiple time to clean interior and remove all plastic drill shavings.
