Brief Description: Cutting/Fitting Test Wheel Fairing Mounting Plates
Spent this evening adjusting the layout, cutting, and checking the fit of several iterations of test plates for both right and left main gear wheels. Finally found the final layout for both sides and ready to cut finals from the 0.063" 6061 T6 plate stock.
Test plates to check alignment and fit before cutting the finals from the heavier stock.
