Continued with cutting inside openings on both wheel fairings. Started by cutting the axle opening on the right wheel fairing. Proceeded to add the sweepback opening to fit around the brake fitting on both fairings, such that it was centered when the bottom edge of the fairing wheel opening was level.
Rough mounted both fairings to check fit and position against wheel fairing mounting plates.
