CHUCK'S WEB SITE
Date:  5-16-2022
Number of Hours:  0.75
Manual Reference:  SNB-L06
Brief Description:  Test Leg Fairing - Left - Continued
Installed the left leg test fairing and was pretty happy with the fit as cut. I may adjust the curve trim at the top to reduce the slight uneven gap at the leading edge to belly skin fit. All in all, ready to use the top and bottom hinge pins to mark where the upper and lower hinge pin holes need to be drilled in the fuselage bottom and the wheel fairing mounting plate.
Leading edge of left main gear leg fairing.
Very slight excess gap at leading edge to belly skin union.  May adjust trim just a bit.
Inboard fairing to belly skin union looks good.
