Clecoed intrument panel brackets and clecoed instrument panel in place.
Drilled hole for wiring harness to pass through in the stick neck of the control stick assembly. Cut, drilled and fit the control stick grip riser tube to set the height and intrument panel clearance of the grip top to the instrument panel bottom edge when stick goes forward and under the instrument panel.
