CHUCK'S WEB SITE
Sonex-B Tri-Gear
SNB-G01
Installing Fuel Tank Oops Fittings.
Acquired larger step drill, and drilled main fitting hole out to 1" diameter. Had to square up the walls as it was a little thicker tank wall than the drill's 1" step cut.
Installed the fuel tank vent fitting.
Main fuels supply fitting installed.
Laying out fuel vent fitting position.
Fuel vent fitting installed.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
