CHUCK'S WEB SITE
Date:  3-9-2022
Number of Hours:  2.40
Manual Reference:  SNF-L04 & SNB-F05
Brief Description:  Left Side Main Gear Mount.
Final trimmed left main gear leg hole through bottom skin. Mounted SNB-L04-02L with the three outboard bolts through the lower longeron, skin and mount. Pilot drilled and clecoed for the six forward rivets across the bottom of the mount.
Checked the 68 degree angle for left main gear leg from the side, and 38 degree angle from the front or rear, and both angles look good.
Drilled and clecoed pilot holes for the 7 rivets on each mount that run up and aft at a 45 degree angle, securing the mount flanges to the airframe. No shims appear to be needed on either side, as contact appears tight.
Pilot drilling and clecoing outboard aft angle flange to airframe.
Both SNB-L04-02L/R main gear mounts are temproarily mounted , but still need the spar tunnel screws.
Main gear leg angles look good and uniform.
