CHUCK'S WEB SITE
Sonex-B Tri-Gear
SNB-L05
Main Brake Lever Assembly
Bent handle angle. Assembled hydraulic brake master cylinder assembly. Located and mounted attachment hardware.
Braking lever will need a hand grip. I plan to fabricate one from two thicker halves of carbon fiber.
Braking control assembly mounted and complete, less handle fabrication and installation.
Brake master cylinder, lever and mounting hardware.
Lever bent to 135 degrees per plans.
Brake assembly installed and ready to plumb.
Sonex-B Tri-Gear Home
1153
142
Cowling
66
140
Documentation
69
81
Electrical System
232
Plans Review
