Brief Description: Instrument Panel Layout Planning - Continued
Did paper manual mock-up to get basic layout, then moved to the computer layout to add the carbon fiber background panel that will overlay the stock aluminum base panel.
Trying to determine where the panel will need to be extended down below the stock panel's bottom edge. Definitely on the far left pilot side to hold the mixture control knob. I still have to come up with the switches, and fuses and/or breakers I want to use, I need to check leg/lap and control stick clearance before extending anything down in the middles or lap areas.
Old-school hand mock-up with paper component cut-outs to define initial layout options.
Computer mock-up with carbon fiber background panel to start providing more realistic visualization.
