Brief Description: Continued Fitting Of Vertical Stabilizer.
Rebolting/attaching the vertical stabilizer main spar. Continued fitting of vertical stabilizer. Clamped forward attach fitting of vertical stabilizer into proper position. Started drilling "tight fit" holes through forward attach fitting of vertical stabilizer and forward spar of horizontal stabilizer using a Letter D drill bit.
Bolting vertical stabilizer main spar assembly.
Drill "tight fit" Letter D sized holes for forward attachment points.
