Brief Description: Trimming Horizontal Stabilizer Skins To Position.
SNB-T01.
Started trimming horzontal stabilizer skins to fit stabilizer to fuselage. Marked a small amount of skin to trim with blue painters tape, then used an angle grinder with coarse scotchbrite wheel to remove skin material back to the tape's edge. Then re-installed the horizontal stabilizer and checked fit again, masking off the next trim. Multiple iterations of this fitting cycle.
Establishing the total skin width before trimming started and marking a small amount to trim.
Removing skin edge material back to the marking tape's edge.
Not quite the specified 160 degree angle from the top surface of the horizontal stabilizer.
