Made a 1/2" aluminum wedge (from round rod stock) for rivetting in tight spaces against an obstruction. Pulled the 5 remaining rivets on the Vertical Tail Forward Spar Assembly and the Rudder.
One rivet shank broke proud of the head, and had to be cut down to the head then smoothed.
Started edge prep on T12-01 Aft Strap.
Rivetting wedge used for rivetting against an obstruction.
Final rivets on rudder against the horn completed.
