T08: Attached Rudder Drive Horn Assembly to bottom of rudder. Drilled pilot holes and clecoed Rudder Drive Horm Assembly into place.
Attached rudder hinge. Drilled pilot holes and clecoed rudder hinge to edge of rudder. Used angle aluminum on edge of table to set the 1.45mm space for the hinge pin loops.
Rudder completely drilled, assembled and clecoed with pilot holes.
