Brief Description: T02: Hor Stab Assy - Skins - Part 2
T02: Continued with attaching horizontal stabilizer skins.
#40 clecoed bottom sides for both left and right skins. Due to number of clecos available, I worked with only the right side of the horizontal stabilizer at this time.
Up-drilled all #40 pilot holes to #30 final size rivet holes for all right side top and bottom holes except the aft top edge where the elevator hinge will be fit and the outboard end where the fiberglass tip will be attached later.
Dissassembled right skin and deburred all skin inside holes.
Getting top and bottom sides of the skins #40 clecoed in place.
Deburring right side skin interior holes after updrilling to final #30 rivet size.
