Brief Description: Created the Center Rib routing jigs
Using the same technique as the nose rib routing jig, I created the center rib routing jig. As with the nose rib routing jig, there are marker holes that represent the center of the lightening holes. I will eventually cut circles in these jigs where those holes go, and will route the lightening holes at the same time I route the edges.
There are some false ribs behind the fuel tank that are also formed with this jig.
Center rib routing jig from the top
Up close and personal with the center rib routing jig.
