Plans: 1. Mount the oil cooler. Status: Not much progress today. I cut the two cables to length and mated the straight 10AN fittings. It appears that neither the straight or 90 degree 10AN fitting produce a comfortable routing of the cables under the oil pan. I have ordered two 45 degree fittings to remake the cables. The upper brackets were finished and installed.
2. Apply cement to the wing leading edge. Status: Complete. I finished coating the right upper wing's felt with contact cement. I am using green tinted 3M Fastbond from Amazon. The color appears identical to the Stewart Systems cement.
