Plans: 1. Hook up the fuel pressure sensor. Status; Complete. The other half of the connector (sensor side) was added. The filter and sensor were joined with fuel line and secured to the firewall. The fuel lines were also protected with fire sleeving. 2. Hook up the starter and alternator. Status: Complete. The power cables were trimmed to fit, lugs installed, then connected to the starter and alternator. 3. Mount the engine. Status: 80% complete. The mounting bolts were replaced with bolts of more appropriate length. The holst was removed and the engine secured.
