Plans: 1. Install fuel pumps. Status: 50% Complete. A mounting bracket was fashoned using 3/4" angle and secured to the firewall. Both pumps were secured in the bracket for a test fit. The first filter element was connected to the shutoff valve. 3/8" fuel line (as called out in the Aeromomentum documentation) was used in an attempt to connect the input side of the pumps. Failure. The pumps and hose barb are clearly too large for 3/8" line. 1/2" would be a better fit. I will have to stop until I can get the right fuel line. The output side also appears to be a poor fit. It is specified as using 1/4" ID tubing. Yet the hose barb is over 0.3" OD. I think these parts are metric or odd sizes.
