Plans: 1. Install the propeller extension. Status: 50% complete. The lugs for the prop extension were installed. With difficulty the last three lugs were pulled into the flange. A small sliver of stainless was shaved off one of the lugs as it was pulled. Apparently the press fit between the flange and lug was a tad too tight. After removing and cleaning the lug it was reinstalled successfully. The extension was a perfect/snug fit and tapped into place with a plastic hammer. 2. Add plate nuts to the cowl panel. Status: 50% complete. I decided to glue backing strips for the plate nuts for the cowl. The initial placement of the hole for the prop flange appears good and doesn't need any adjustment. The back surface of the prop will be about 1 inch from the cowl with a 4-inch extension. I don't know if that is too close but the larger 6-inch extension would have placed the prop three inches from the cowl surface.
