Brief Description: Throttle Quadrant and Radio Mount
Plans: 1. Add wood veneer to the throttle Quadrant mount. Status: Complete. 2. Finish modifications to the radio mount. Status: Complete but.... After reassembling the radio mount I found that the radio would not power up. I haven't used the radio since it was installed some time ago so it is unclear when it stopped working. Initial troubleshooting indicates the failure is in the radio itself. That said I don't know if something about the air vehicle's 12 VDC battery may have induced a failure. I never examined the12 VDC battery levels while operating the engine. I need to verify the voltage levels are acceptable.
