Plans: 1: Restart my project. Status: I needed to attend to a number of other non-aircraft projects. Unfortunately this resulted in an unplanned two-month break in my build. Today is my first day back and I am reacquainting myself. That said I decided to run the engine for five minutes to wet the internal parts with fresh oil. The engine kicked over beautifully and purred. I also needed to clean up the hanger a bit before restarting. Done. 2: Fix the N-Strut passages. Status: When the N-Strut passages were originally measured for the upper wing I made them too small. As a quick fix I simply cut the AL sheet wider to accept the strut. Before covering the wing I needed to fix the openings and add plate-nuts. Done. I also fabbed new covers for the larger openings.
