Plans: 1. Cover the right upper wing. Status: 30% complete. I covered the bottom surface of the right upper wing. This went uneventfully. I had wondered how difficult covering the scalloped edge would be. The answer is not difficult. Basically all you need to do is slit the fabric about every 2.5 inches to smooth the curve out. Perimeter tape will be done with bias tape. Bias tape will enable an inside curve.
