Plans: 1. Continue fabric covering. Status. The wingtips of both lower wings and the remaining trailing edges were taped. The rudder and elevator were started as well. 2. Rework the aileron control. Status: I was unhappy with placement of the control horn for the ailerons. It was off center with the push-pull linkages. I drilled a new hole further forward to improve things. A simple bolt was used in place of the eye bolt to keep the pivot action intact.
