Brief Description: Weight Check, Lower Wing Tips and Gauges
Plans: 1. Add the oil temperature and water temperature gauges. Status: Complete. I received two new gauges the other day. I installed them into the instrument panel today. A combination oil temperature and pressure gauge on the lower right. A water temperature gauge on the inside left. Still waiting on a fuel pressure gauge to arrive and the tachometer. 2. Add lightening holes to lower wing tips. Status: Complete. Just an extra touch to reduce the weight.
Speaking of weight I weighed the air vehicle today. Left wheel was at 180 lbs. Right wheel was at 170 lbs. Tail wheel was about 78 lbs. Since the engine should be in the range of 200 lbs, I am at about 628 lbs. Not included in the calculation is the fabric and paint. Let’s say that is another 100 lbs for 728 lbs. With pilot and full fuel it will be in the neighborhood of 1050 lbs fully loaded.
