Chris' Web Site
Date:  9-28-2019
Number of Hours:  4.00
Brief Description:  Pitot & Static Syatem
Plans:
1. Install Pitot and static tubes.
Status: 80% Complete. I started to assemble the various parts of the Pitot system. The tubing routes from the Pitot tube through the right wing conduit then under the seat to the instruments panel. I decided to run the tubes under the seat using tubing separators to hold it securely. There is a slight concern that should the tubing drop from the underside of the seat it could interfere with the elevator pushrod. Should that happen I think the leverage of the joystick will easily overpower the tubing. Hence only the Pitot should fail. The actual tubing has yet to be installed. I also need to create a bracket for the bulkhead connectors that allow the wing to be removed.
Pitot Conduit Mounted with Hose Clamps
Pitot Tubing Seperators Under Seat
Pitot & Static Tubes Under Wing
