Plans: 1. Continuing the fab of trim plates for the right upper wing. These plates serve multiple purposes. The first being to closely seal the passages where the struts and bracing cables enter the wings. The second is to create an inspection port for the internal drag and anti-drag bracing. And last to provide some surface area to glue the fabric down near the openings. Status: Completed the rear plates for the "N" struts and cabane. These plates were created with the benefit of having done the left side awhile back. At that time is was observed that the left side’s plates should have been bigger. In fact I will need to rebuild them. The sweep angle of the "N" struts was such that they interfered with the edge of the plate.
