Plans: 1. Assemble the left upper wing. Status: 95% complete. After some hassle I was able to install the upper left wing on to the air vehicle. Unfortunately I found that the trim plates interfered with the "N" struts and will need some modifications. There was also some issues with the forward landing wire. So status wise I am taking a hit. Other than that things went well. I riveted the L. E. flashing down after having leveled the wings. This appears to have been a good technique as I found the flashing did appear to shift slightly at the root edge. One down or is it up.
