Plans: 1. Continue center section fabrication. Status: Fabbed the trim plates for the C.S. Plate nuts were added to the surrounds for the attachment of trim plates. I also made the trim plate blanks and attached them to the surrounds. The next step will be to cut passage holes for the cabanes. I expect this to be a bit tricky getting the holes precisely located.
