Chris' Web Site
Date:  12-28-2020
Number of Hours:  4.00
Brief Description:  Louver Assemblies & Engine Compartment Cover
Plans:
1. Paint the louver assemblies
Status: 50% complete. I have been simply sanding the aluminum prior to paint recently. In the case of the louvers I decided to chemically etch them instead. This is because the louvers could not be sanded easily with all the odd angles. The prep process is complete. I am letting them dry overnight.
2. Paint the engine compartment cover.
Status: 25% complete. I have applied three coats of primer on one section of the cover. I painted the aluminum ribbons black where the cover seam presents.
3. Add a spring loaded cover to create a "grip" area behind the cockpit. This will provided a dedicated gripping spot to enter the cockpit just behind the pilot's seat.
Status: Started. The core pieces have been cut from some .020 scrap. I squared up a half inch tube with a torch and hammer to be used as the hinge pivot.
Primed Left Engine Compartment Cover
Alodine Dipped Louvers
Spring Grip Assembly Pieces
Copyright © 2001-2021 Matronics. All Rights Reserved.
