Chris' Web Site
Date:  3-11-2020
Number of Hours:  3.00
Brief Description:  Lower Cowl & Exhaust Bracket
Plans:
1. Fab the lower cowl bowl.
Status: I mounted the lower cowl to the fuselage with the addition of securing the trailing edge to the lower engine cover. The holes lined up perfectly. I also drilled the holes for the plate nuts on the lower engine cover. The nuts are back ordered but I was able to make this small progress in the meantime.
2. Fab a brace for the exhaust bend.
Status. 25% complete. I decided the bracket I made yesterday was not the best approach. So today I am trying something slightly different. In this case the brace will be attached to the bend with a clamp as opposed to welding. This will make maintenance a little easier.
3. Mount the muffler to the bend.
Status: Complete. To exhaust ben slipped over the muffler loosely. I cut some slots in it and squeezed it tightly to the muffler with a hose clamp. This has greatly improved the rigidity of the set-up.
I ran the engine for a few seconds today to circulate the oil a bit. For this case the muffler was installed. It started easily but did stall when I throttled it up. Perhaps it was simply cold and needs to warm up a bit. Without the prop I have been limiting the run time. The prop, by the way, is very late now.
Lower Cowl Mounted
Lower Cowl Mounted
Exhaust Bend Clamp
Exhaust Bend Clamp
Exhaust Bracket
Exhaust Bracket
Copyright © 2001-2021 Matronics. All Rights Reserved.
