Chris' Web Site
Date:  2-7-2020
Number of Hours:  4.00
Brief Description:  Cowl Installation
Plans:
1. Install the cowl.
Status: 10% complete. The cowl needed to be tailored to fit the nose properly. Due to the contours I found that creating a straight cut line was going to be a problem. I rediscovered a laser level I had and used it to paint a line on the cowl. Tracing the laser line on the cowl surface provided perfectly straight and perpendicular cut lines. Plate nuts and other tie points will be added next.
Laser Leveled Cut Line
Laser Alignment to Engine Hub
Side View of Cowl
Side View of Cowl
Copyright © 2001-2021 Matronics. All Rights Reserved.
