Chris' Web Site
Date:  12-2-2019
Number of Hours:  4.00
Brief Description:  Cockpit Coaming & Side Panels
Plans:
1. Add trim sections to the cockpit for attaching fabric.
Status: Complete. The rear and forward cockpit trim sections had gaps at either end. Hence it would not be possible to bond fabric to these areas. Sections of alumunum were added to eliminate the gaps.
2. Tailor the side panels to fit better.
Status: Complete. When I attempted to reinstall the side panels they were found to have new points of interference. Primarily the Pitot and static ports needed a passage way. I also cleared some additional room for the aileron cables.
Right Cockpit Coaming Trim
Pitot & Static Feed-Thru in Side Panel
Left Cockpit Coaming Trim
