Plans: 1. Install cockpit coaming. Status: Installation focused on the left and rear sides of the cockpit. Just as with the right side a flange and tube were secured to the side. A PEX tube was added to the rear of the cockpit in preperation for the foam padding. The tube was shaped using a torch and secured temporarily with ties. Shome shoe glue will be injected into the gaps to make things perminate. 2. Install fuel pressure gauge. Status: I received the fuel pressure gauge a few days back but did not have the correct screws to install it at that time Today's installation was simple. I still need to wire it.
