Chris' Web Site
Date:  3-28-2019
Number of Hours:  4.50
Brief Description:  Top Panel (Bonnet) Tailoring
Plans:
1. Add a support bridge to the bonnet.
When I last had the bonnet on the aircraft I found that the act of securing all the screws contorted its shape slightly. I determined that some stiffening under the hood was in order.
Status: Complete. I added a bridge like member to the underside of the bonnet. It was a 0.032" right angle curved into the same contour as the rest of the bonnet with a crimp tool. Worked perfectly.
2. Trim windscreen.
After the installation of the center section it was apparent the windscreen was too tall.
Status: Complete. I trimmed about 2.5" off the height and reinstalled the part.
3. Create lower cabane trim plates.
As with the top of the cabanes the lower end requires trim plates.
Status: 25% complete. With the bonnet in place I started the creation of templates using marking tape. Once finished the templates will guide making the trim cutouts for each cabane.
Bonnet Support Bridge
Reduced Size Windscreen
Lower Cabane Trim Templates
