Chris' Web Site
Date:  9-26-2018
Number of Hours:  5.00
Brief Description:  Brakes & Coming
Plans:
1: Drill holes into the turtle deck for stitching the coming leather in the future.
Status: Done. This task went fairly easily. I used the same pipe foam insulation to gauge the correct hole location and drilled 1/8" hole every inch. The holes will allow for passage of a sewing needle later.
2: Trim the brake pedals, fab and attach the top plate.
Status: 90% complete. The brake pedals had been located and secured from the bottom only. During application this would have resulted in a torque on the bolts. While it probably would have held up given the strength of materials I was bugged that the stresses involved were unbalanced. To make a top plate I needed to conform the 1/8" stock to mate to the carry through. Getting the shape right took heat and time with a hammer. I haven't secured it yet as I still need to add the cables.
Last I trimmed the width of the brake pedals to allow for some additional heel space. Time will tell if they bend in use.
Coming Stitching Holes
Brake Top Plate
Brake Top Plate
Trimmed Brake Pedals
Copyright © 2001-2021 Matronics. All Rights Reserved.
