Plans: 1. Use Horizontal Stabilizer to determine rear fuselage rib spacing.
Status: Complete. I laid the stabilizer out on the table at a right angle to the centerline I drew previously. The tall aluminum right angle jigs were attached to the table to set and hold the spacing that the longerons will be tailored to.
2. Install remaining fuselage ribs.
Status: Completed the top and bottom cross braces. Added the gussets for the diagonal cross bracing.
