Plans: 1. Install the engine compartment panels. Status: Complete. The covers have been installed with the top louvers. I also added the side panels to verify the fit. A few adjustments will need to be made. Having everything line up simultaneously does happen but takes a while. I have decided to open up the screw holes slightly to create a looser fit. It won't be noticed and will ease alignments. 2. Complete the transponder harness installation. Status: Complete. The new panel is installed and tested OK.
