Plans: 1. Hook-up fuel pump wiring. Status: Complete. Power to the fuel pumps is supplied from the 12V battery bus near the firewall via the master switch and individual circuit breakers on the instrument panel. The switched master power is distributed with a bus bar where all the individual power connections are made. All wiring is 12AWG with the exception of the panel indicator lamps. For those 26AWG wire is connected at the terminals of each pump. Hence when there is power at a pump's input the lamp should illuminate. The wiring is wrapped in plastic sleeving.
