Status: Complete. Templates appear to line up well enough. 4 caps ready. The 5 hole pattern is pretty good. Eyeballing the axle center is probably placing things off-center slightly. How much I can't say but since the holes will be oversize slightly it won't likely matter. I will drill one set and check by mounting before drilling the others. As long as the holes are big enough for the lugs to pass but small enough for the washer and cap to cover it will look and work fine.
