Brief Description: Bluetooth Adapter and Oil Change
Plans: 1: Setup Tuner Studio on the laptop using the Bluetooth adapter. Status: Complete. The PC program ran off the Bluetooth adapter without any issues. Of note is that the adapter's M switch setting is appropriate running at 115200 Baud. 2: Setup the Mobisquirt iPad program using the Bluetooth adapter. Status: Failed. It turns out that the version of Bluetooth for iPads is different from other devices. An Android based device is necessary to interface with this adapter. After some searching on the internet for an appropriate iPad adapter I decided it would be better to change to an Android based tablet of phone for this feature. In the end I selected a MAVIN pay-as-you-go Android based phone. It's on order now. 3. Change the oil in the reduction drive. Status: Complete. At 6.5 hours the drive was past do for an oil change. The only issue here is that your must remove the nose cowl for access. Bit of a pain but straight forward.
