Plans: 1. Fabrication of the upper wing gap seals. Status: 95% complete. Having dried overnight the seals were placed over the wing gaps. Holes were cut to allow passage of the turnbuckles. Installation was fairly simple. By opening one ground cable at a time you can thread the seal on. Once both cables are threaded you simply mate the two Velcro strips. The trailing edge still needs some treatment to ensure the ends don't lift or fray. 2. Secure the temperature gauge calibration trim pot in the electronics bay. Status: Complete. The trim pot resistance was measured to be 314.1 Ohms. It is now installed with a dab of ShoeGoo near the terminal boards. The original fixed resistor was 330 Ohms. So I was correct that the fixed resistor value was incorrect.
