Chris' Web Site
Date:  2-6-2021
Number of Hours:  4.00
Brief Description:  Weight and Balance Check.
Plans:
1. Perform weight & balance check.
Status: I was able to borrow professional scales from an aviation friend, so I could finally do an accurate weight and balance for the air vehicle. The system includes three scales each with a capacity over 1000 lbs.. I completely assembled all the parts in their final locations. I also added 18 lbs. of lead weight to the fuel tank to simulate 3 gallons of fuel (minimum load). I checked all weights with me sitting in the cockpit and outside.The result is very different from the predictions. It turns out that the location I had been using for the pilot's moment arm was way off. I had it at 47 inches and the truth is 51 inches. This means I am very tail heavy. The new battery needs to be moved forward of the wings. I also need to cut as much weight from the tail as possible. I may also need to add weight to the nose. Conversely I will need to move the pilots seat forward.
Actual weights (3 gallons fuel):
Pilot 216 lbs.
Laden Aircraft:
LW 469 lbs.
RW 462 lbs.
TW 86.2 lbs.
Total = 1017.2 lbs.
With 12 gallons fuel flyoff weight 1071.2 lbs.
Unladen Aircraft (3 gallons fuel):
LW 387 lbs.
RW 379 lbs.
TW 34.6 lbs.
Total = 800.6 lbs.
Empty weight without fuel = 782 lbs.
