Chris' Web Site
Date:  1-13-2021
Number of Hours:  4.00
Brief Description:  DC-to-DC Converter, Equipment Rack & Headset Jacks
Plans:
1. Mount the regulated 12VDC terminal block to the sidewall.
Status: Complete. A terminal block for the 12VDC comm and transponder power was added to the sidewall on the inside surface. Terminals etc. were added and connected to complete the hook-ups. I decided to perform a full test of the radio and experienced a problem. The headset microphone is not being picked-up by the radio. After some troubleshooting it appears that the radio itself failed. That is all the wiring is fine. I am considering options to fix the issue.
2. Add a backing plate to the equipment rack.
Status: Complete. Given that I mounted the transponder to the underside of the tray it left the upper surface available as storage space. I added a backing wall to effectively enclose the space. I am sure it will come in handy for something. Perhaps it will be used for propane to fire guns. Hmmm.
Converter Terminal Board
Equipment Rack Backer
