Plans: 1. Continue painting the engine compartment panels. Status: Complete. 2. Complete the transponder harness installation. Status: 95% complete. I fabricated a new circuit breaker panel for the transponder. I changed the orientation of the circuit breakers from horizontal to vertical. This will allow the headset connectors the necessary clearance. I also enlarged the panel to incorporate the audio connector and some additional jacks for the headset. I also connected up the static pressure port to the rear of the VDI gauge.
