Plans: 1. Weight check. I thought it would be a good opportunity to weigh the air vehicle with the wings newly installed.
Right Wheel: 335 lbs. approximately. The scale was unable to lock in the weight). It is probably outside the useable range of the bathroom scale. Left Wheel: 330 lbs. approximately. Tail Wheel: 75 lbs. On the ground. I.e. not in level flight.
Given the scale's failure to lock in the weight I can only hope the weights are close to the readings. If that is the case the air vehicle is approximately 750 lbs. in the current configuration. There is probably three gallons of fuel in the tank at the moment. Hence I expect final weights to be as predicted. With a pilot and fuel the ramp weight will be a little over 1000 lbs. That assumes less than 10 lbs. will be added with the fuselage covered.
