Plans: 1. Add the cross pattee to the upper wings. Status: Complete. The process here is to place the mask on the wing. Outline it with fine-line masking tape and paper. Then remove the central mask leaving the area to be painted revealed. One heavy coat of matt black spray paint is then applied in two passes. 2. Touch-up the cross pattee on the lower wings. Status: The right wing is complete. The lower wings require a second coat of black. The original coat on the right wing was a semi-gloss and I ran out of matt black on the left wing. I decided I liked the matt black color best so I'm applying a second coat in both places.
