Chris' Web Site
Date:  11-3-2020
Number of Hours:  5.50
Brief Description:  Lower Wings & Center Section
Plans:
1. Apply a third coat of white paint to the lower wings.
Status: Complete. With two coats of white the coverage was still a bit uneven. I added a third coat and now it looks uniformly white.
2. Add bias tapes to the center section's trailing edge.
Status: Complete. Due to the thickness of the center section's trailing edge I needed to make custom bias tapes. Using a large section of scrap fabric, I made diagonal cuts to rotate the weave 45 degrees. This allows the tape to stretch into the scalloped T.E.. If there is a next time I will do this in the future for the wings. The store bought bias tape is very expensive. It turned out that I only cut short sections for each scallop. I could have easily done this with waste fabric from covering the wings.
Right Lower Wing Insignia Field
Large Custom Bias Cut Strip
Center Section Trailing Edge
